k so need imput
k i just finished a depron boat and it works great except for when it starts to hydroplane it can flip on a had turn. the other thing is it has no reverse so thats not to good. to fix these problems i was thinking about ading 2 pontoons that went backwards of the boat and put to the sides. there is no problaem with the prop hitting since its a puller. how does that sound to all yall?
next thing is im starting to plan my next build. i pretty sure ill use the same motar speed control and battery. i think ill keep the same one eighth depron for the inside supports and then take some 2 32nd inch depron for an outside followed with either fiber glass(would that add a lot of weight) or epoxy some kevalar cloth to it and put a coating of epoxy over the Kevalar. does this sound good? would kevalar work or not?
