RCU Forums - View Single Post - Taking Orders For Hanno Piston/Liner Sets
Old 04-22-2008 | 08:30 PM
  #110
Atlanta 60
My Feedback: (18)
Default RE: Taking Orders For Hanno Piston/Liner Sets
ORIGINAL: cmulder
since i am "just" a sports flyer i like to ask if the liner for the "plain" (side exhaust ) liner is the same as the rear (hano special) version?
Becouse the fs-p has a peeling liner so i doubt it will last long
I assume you meant "SF-P"...If so...The SF-P and the RF-P (Standard Version) use the same liner but a little bit different piston...The SF and RF case's have a pin which "clocks" the piston liner in the correct position...I attached a picture showing the difference between the SF and RF pistons...
I hesitate to say weather or not these Hanno sets will work in the SF-P due to those reliefs in the SF piston...I just don't know...
I've been told the Hanno liner will work in the "Standard RF" just fine...But then again the pistons for the RF and the Hanno version are the same...
Anyone??
Chuck
