RCU Forums - View Single Post - SPEKTRUM AR6200 bind issue
Old 04-23-2008 | 12:49 AM
cobra525's Avatar
cobra525
Default RE: SPEKTRUM AR6200 bind issue
Thanks to all for your support. I beleive I found the problem. I changed the esc to a different one and had 3 flights without incident. Hope it stays like that. The "BAD" esc still seems to work fine on 72mhz as I put two flights on it with my mini edge. 2.4 technology is certainly picky when it comes to voltage flow, receiver location, and older equipment. Both systems have pros and cons I guess. The way I see it is - APPLES and ORANGES. Some people will say 2.4 is the best thing since sliced bread, and I do too after spending 400.00 to experiment. At the end niether system to date guarantees your bird will go back home with you 100%. Its just another system.
