RCU Forums - View Single Post - looking for speed model
Old 04-23-2008 | 09:26 AM
bob27s's Avatar
bob27s
My Feedback: (19)
Default RE: looking for speed model
ORIGINAL: kiosk
I have the OS75ax already on there, so only need tuned pipe.
So the prop part is where my ignorance comes in because I thought pitch is more relevant for speed?? anyways I moved down to 12x10 and now is in 12k range, not even close to 16k by a long shot, do i need larger smaller prop or pitch for speed??
The 75AX likes to run around 13,000 rpm on the top limit.
Select a prop/pipe/exhaust setup that gets to that number and you will see pretty much its best performance. It is not a 16000+ rpm engine.
As for a speed choice.....
my turn-key easy speed setup......
GP Viper
TT 46-pro
Jett Muffler
9x7 or 8.75x8W prop
clip 5" off of each wing panel at the tip to cut the wingspan by 10".
Results: 130+ mph, very good handling plane, reasonable landing speed, no bad habits - not expensive.
