Exploded View of Older Pump?
Jeff,
The large brass screw adjusts the regulator diaphragm. It's supposed to be adjusted so that the engine is running at peak RPM with the high-speed needle at one turn out.
The return line will open only when the engine's running at low throttle and the pump is moving fuel. A spring on a check valve keeps it closed otherwise.
Usually, fuel will move through the pump only when it's turning. You can't really blow through it and expect any results.
