ORIGINAL: David Jackson
Personally, I would suggest you avoid the Formost 150 from Nitro Models as an intro to jets. There are many other good choices available. Also before you make a final decision, you may consider attending some of the rc jet events to check out what's available.
Formost 150 is not a turbine Jet model and never will be. Is a sub-compact Boomerang coming out some time later in 2008?.
