RCU Forums - View Single Post - u-can-do 60
Thread: u-can-do 60
Old 04-24-2008 | 08:01 AM
  #1557
AcroJo's Avatar
AcroJo
Default RE: u-can-do 60
ORIGINAL: HoverLoW
At the end, I installed the ruder servo in the bottom of the fuselage. I am using two push rods like a pull-pull sistem.
Swap out the push rods for cable. I had pushrods for a while and the tension created by the geometry of the set up would wear out the connectors quickly and put strain on the servo and mount. cable solved that. good luck. joe
