RCU Forums - View Single Post - CMPro Extra 330L 50 size
Old 04-24-2008 | 08:18 AM
GuyP
Default RE: CMPro Extra 330L 50 size
Hi all
Well still not got a great deal done yet. Tried the wings on for size. Seemed to fit nice and tight. One of the criticisms I heard was after removing the wing pole a few times it becomes a loose fit. Mines stayin put then. May even glue in after a few flights.
Servo hatches installed, so far so good and no complaints about the hardware like I have seen on other threads about this plane.
I did start sanding the fuse where the stabs are to be glued last night. Checked pole for size and its very tight, so tight in fact the pole is permanently fitted into one stab with no glue. Any ideas how I should remove it without breaking so I can glue it? Or should I leave well alone considering I will take great care in glueing the stabs to the fuse.
I have a 12x8 apc prop for the Saito FA80 so far, any other props I should take for the first test? I recall somebody saying somewhere they used 14x?
Also what is the easiest way to change the thrust angle from the standard?
Cheers all
