Aeropoxy
I believe Aeropoxy is just epoxy. Hence the "poxy" in the name. It is, no dounbt, just a re-labeled tube from some manufacturer that you & I can go buy it cheaper from direct. I sometimes use similar Loctite & 3M stuff from McMaster-Carr or Grainger supply houses.
