going crazy--engine quits
try sealing the pressed & threaded fittings that are on the remoted needle block........(the one's that the line's push on to), my 46 was sucking air through the pressed in one. i used thin ca glue to do the sealing. been fine for the last 3 years with no more trouble..........good luck!!!!!!!!!!!
