RCU Forums - View Single Post - Thoughts on this charger?
Old 04-25-2008 | 09:27 AM
2slow2matter
Default RE: Thoughts on this charger?
Looks pretty good, but it only charges one at a time. Usually, if I'm quick charging a plane, I'll go ahead and charge the tx back up while I'm at it so that I'm not down again in an hour or two waiting on the transmitter to charge. however, most of that has been corrected now by going to a 1500 mah tx battery, which will basically last me all day.
I use the hobbico quick charger that does both at one time. However, for the money, this seems to be a good deal. It does not say, howver, if it comes with a transmitter charge adapter, just a Z connector, so if you were gonig to charge your tx through it, you would have to buy that adapter, I'm sure.
