RE: Thoughts on this charger?
I only saw one charger in the OP, which was the peak charger. He mentioned wanting to quick charge. I personally would not have a need for an AC quick charger. All quick-charging should be done at the field, meaning you should go with a DC powered charger. At home, you should charge your batteries in a more responsible manner to make them last longer. JMO
