RE: BME .90 (15 cc) Super Tigre conversion
With the cost of gasoline going so high...why convert to gas in this small engine size? If you want a slow idle...use a heavy prop and prop hub, which will act more like a flywheel. You can also look around and get electronic ignitions real cheap. With electronic ignition, the engine should just tick over on idle (even using glow fuel) !!! Capt,n[)]
