RCU Forums - View Single Post - Power system
Thread: Power system
Old 04-25-2008 | 11:45 PM
Xpress's Avatar
Xpress
Default RE: Power system
A little more info please? It helps us to help you if you can provide us with info such as battery brand, mah, discharge rate, and what speed controll you're using.
This sounds like you are not using the correct battery. Are you using a 3 cell, 2100 mah with at least 15C discharge, and are you using high powered plugs, like Deans?
