RE: Rolling Circles without Rudders!
Quote:
"To do a proper rolling circle you lead with the rudder.. you dont start rolling first"
__________________________________________________ _________
OK...let's say you are rolling to the right. Do you lead with right or left rudder?
Left rudder moves the nose of the aircraft left on yaw axis and this becomes nose high attitude as the aircraft rolls 90 degrees right. If you lead with right rudder, you would get nose down attitude as the aircraft rolls 90 degrees right.
Regards
JC
