46FX & Dazzler
Texfox:
The Dazzler uses a wire rope cable in a plastic outer jacket to control the throttle. If the plastic outer jacket is a little too short, either at the throttle end or the srvo end, the cable will bend before it has a chance to open the throttle fully. This may be one of your problems since the engine checks out ok on the bench.
Good luck.
Pat
