RE: Welcome to Club SAITO !
I'm having a horrible time setting my ls needle on a saito 100. My HS needle is peeked at 9000 on 30% coolpower and my LS has a very small "sweet spot" that is within 1/4 of a turn. Problem is if I lean it, it idles way to high then dies. If I richen it, it will run then die within a minute. It always starts immeadiatly after dying. Could the valves be too loose? If I put them on the feeler gauge the motor vibrates horribly. I need to add that this motor ran and idled great when it was sloppy rich but only peaked at 8100 rpm and that won't hover my 7 LBS plane. Please tell me what to do!!!!!!!!!!!!
