RE: Unusual interference
Do you have a non conducting throttle push rod and no metal to metal in the connection to the throttle arm? Are you using an onboard glow plug igniter? Either of these might cause a problem. I'd still suspect some metal to metal joint vibrating somewhere in/on the plane, especially if the interferance only occurs with the engine running.
