RCU Forums - View Single Post - PRODUCT ALERT - STOP USING IMMEDIATELY
Old 04-28-2008 | 12:15 PM
  #55
RedcatRacing's Avatar
RedcatRacing
Default RE: PRODUCT ALERT - STOP USING IMMEDIATELY
ORIGINAL: impune
awesome. the problem was the digital was on normal and not reverse was the problem. reverse it and works perfect.
i read the return, whats the turn around on this? i really want to play with this. can i take the other one from the hurricane or the teaxxas to use with the avalanche while i wait for the exchange..
man too bad i really liked the fm look even though the digitl looked confusing, it was digital and cool.
can i upgrade to a digital am? if that is what you are replacing with?
darin, you rock and appreciate all the help.
We are turning around the returns within 24 hours.
You can surely use another controller that you have laying around. If its FM, you only need to swap out the crystals and you are good to go. If its AM you will need to swap the receiver as well.
Darin
