try putting tiny holes right in front of the wing tube on both sides of the fuse at 4" back from where the leading edge would be. Then run a thin piece of wire/string through the fuse with the wings on but not bolted tight to the fuse ....hang the plane...problem solved
...tiny holes will be covered when wings are attached !
