ORIGINAL: Barrrick
RICK HERE ON LUNCH TIME AT WORK
VIC SET UP THE HBKS WITH A DEAN CONNECTOR
The first attempt to connect the batt. to the ESC was so difficult, the connectors are so tight
at the END of the first flight( trying to disconnect one of the poles (negative, I think) was ripped off and I need to re-solder it
any SUGGESTIONS from my more experienced group on how best to handle this problem ?
is THIS hardness / tightness
the standard for DEANS ?
would it be better to have
some other kind, like the ASTRO FLIGHT, for example ?
I will read tonight when I m back home
RICK
Rick,
I don't know what could have happened. They're supposed to be a little snug, and I didn't have any real problem with it here...it worked well. I have a few here that are actually too loose and I had to adjust them to be tighter. I guess what I'm saying is...even though they're deans connectors, it looks like the standard varies from batch to batch (from what I'm seeing).
