Yak-3 Construction
Well after a long Month finally we got some good weather!
Out I went and got the Heavy Aircraft inspector to check out the YAK3.........
Wel all checked out OK ............. exept ........ the CG!!
No I did not do the calculations wrong ,,,,,,,,,,, just measured at the wrong place!
So I ended up doing some fast TAXI's to the point were the wing would start lifting and then chop the throtle off.
Changed the prop to a 14x6 for the SAITO 120
got a digi shot of the YAK3 passing infront.
Next week looks like it will be the test flight! (Weather permiting).
Will post pics!
Regards
Erick
