RCU Forums - View Single Post - Cannot tighten Prop!
Old 04-28-2008 | 07:31 PM
Steve Steinbring
Default RE: Cannot tighten Prop!
Bring the engine up against the compression stroke, then position the prop so that it will windmill parallel to the ground if dead stick. Then slowly tighten the prop nut until the prop seats. Once the prop is seated tighten the nut down firmly. This might take a couple of tries to get the prop into the desired position wanted.
