Hmm.. Tip: dont go to hotbodies.com. Porno site.. LOL
Here are the raves for the Dirt Demon:
Check out some of the MANY advanced features of the Hot Bodies Dirt Demon Monster Truck:
- Massive 7 inch diameter tires (dwarfs T-MAXX, Savage, and others)!
- HUGE Hot Bodies Dirt Demon truck is over 18 inches wide.
- HUGE, POWERFUL .26 SIZE BIG BLOCK NITRO ENGINE!!
- Innovative handheld electric engine starting system!
- Fully independent wishbone suspension.
- Extra long suspension arms.
- Pillowball suspension linkage.
- 8 ALUMINUM shocks soak up the rough terrain.
- Huge 4" long suspension travel.
- Strong 3mm thick aluminum alloy chassis.
- Comes with fully enclosed and protected radio gear.
- 2 speed transmission with reverse.
- Installed 3 channel radio system.
- Good looking Silverado pre-cut, painted, and trimmed body.
- Comes with pre-mounted and glued tires.
- Even comes with a glow plug heater and a wrench!
Check out the starter:
Highlights:
Aluminum shocks. Not plastic!
.26 engine! Should have a tad more torque than a .21 but it all depends on what engine were talking about. So I guess we cant say much till we look at em go.
From what I understand.. This MT will be cheaper than the BFT.. while actually giving you more!
This MT comes with everything you need including the glow plug and all. Only about 10 bucks.. but thats 10 bucks you dont have to spend extra! (for a first timer).
MGT:
Overall length: 22" bumper to bumper Chassis type: Extruded aluminum channel
Width: 17.25" wide Chassis material: Aircraft-grade aluminum
Height: 10.75" to top of cab Drive axles: Big universals
Wheelbase: 14.5" Slipper clutch: Disk type
Tire dimensions: 6.75" tall, 3.5" wide Transmission: 2 speeds forward, 2 speeds reverse
Weight (RTR): 12 pounds Bearings: Yes
Engine: .21 size rear exhaust Suspension type: 4-wheel independent A-arm style
Starter: Dual-function starting system Shocks: 8 oil-filled, composite bodied
Air filter: Double-stage foam
Manifold: Aluminum Electronics
Exhaust: Dual-outlet muffler Radio: Associated XP-3 3-channel
Fuel tank: Large capacity, dual pickup (runs upside down) Steering servo: Associated metal gear
Throttle or shift servo: Associated
Highlights:
Dual exhaust?!
I wonder what the price will be. The dirt demon is actually pretty expensive (retail is like 500 bucks). Even if its 400 I'm not sure I'd buy it. I'd personally go for a rolling chassis, but I'd rather buy the MGT over the Hotbodies if theyre the same price.
Now TA.. RELEASE THE DAMN THING!!
ram
