RE: aileron adjustment?
thanks for the replies, it's on my Multiplex Magister. one servo operates the ailerons. I had them adjusted level with the wing and wanted to try this out. I was thinking about modifying the wings for two servo ailerons so I could program flaperons in my TX mainly to shorten the take offs, but if I can get more lift like this that would be nice.
Minnflyer, how much droop do you normally give your planes when doing this? is 1/16 enough or should I give it a little more?
