RCU Forums - View Single Post - Question About Elevation and Engines
Old 04-29-2008 | 01:38 PM
Nathan King's Avatar
Nathan King
Default RE: Question About Elevation and Engines
Typically, when increasing elevation the engine must be leaned. As altitude increases air density decreases. Remember, the mixture is simply a ratio of air and fuel, therefore less air density requires less fuel to maintain the ratio. This is also why on a hot humid day the engine is typically leaned out a little. Heat and humidity also reduce density.
