RE: aileron adjustment?
I have found that the model will usually respond much better if both ailerons are slightly up (not down), especially if the airfoil is flat bottom or Clark Y type. You may find it quite interesting to experiment a bit with aileron position. I'll bet you find the plane flys better with both ailerons slightly up.
