RE: Texas RC PLanes
Well, I don't know how big you battery is??? But unless it's a car battery, I'd say yes!! The fuse is cavernous. You may need to mod a mount, as I will. I'm waitng on a motor, so i can get an idea where the CG is without a battery. The opening in the cowl is big enough to slide it in under the motor, so the wing doesn't have to be removed to change it. But that idea will have to wait till i can see if it can go that far foward. Here's a quick peek at what it looks like. You gotta wanna Volt Bolt!
