RCU Forums - View Single Post - Smoke Question
Old 04-29-2008 | 10:06 PM
KC36330
Default RE: Smoke Question
if it's like the Tam system, the pump won't turn on and pump if you cycle the power and have the TX in the smoke ON position, it has to be cycled to the smoke OFF position to reset. check it with the turbine off and make sure the pump is turning back on after the power cycle.
on the smoke sticks, the exhaust blast usually causes a slight suction on them slowly drawing fluid out.
