RCU Forums - View Single Post - Redcat Racing Tremor Thread
Old 04-30-2008 | 01:17 AM
  #33
jpilkinton's Avatar
jpilkinton
Default RE: Redcat Racing Tremor Thread
ORIGINAL: 3browns
We received our 1/16 Tremor today and are having some problems, any help would be appreciated since we are new. Got the truck running, tried out a few trips around the yard and now we have no steering control. We've changed and checked everything with the batteries, and wires and adjustments to the trim doesn't do anything. Also the rear wheels turn freely but don't run on 4 wheel drive.
If you pick up the truck and turn the wheels with the control, do they turn? Check the servo connector on the RX in the battery box. I can not get my box to completley shut. If, they do not turn, swap the steering servo leads with the throttle servo leads. You should be able to pull the throttle trigger and the wheels shoud turn. If they don't with switching the leads, your steering servo may be bad. As far as the 4 wheel drive problems, if you hold one of the rear tires and spin the other rear tire, the front tires should spin also.
