RE: Black Magic VF3 Build Thread
okay after the first hour sanding the k-36/DCC white base - I am really impressed that the addition of the white DCC even improves the sandability of the k-36, seems to fill pin holes better and is a slightly harder coat, but that makes it even better smoother base - sanding with 320 and 400 grit dry.
one of the fuses is almost completed in about an hour - it's going to take at least 2 full hours to sand out to 400 for each plane -
