RCU Forums - View Single Post - eq6 charge jacks
Old 04-30-2008 | 09:44 AM
rrritchey
Default RE: eq6 charge jacks
Hi Matt,
No, that would not be acceptable. The traces from the charge jack to the system are too small to handle more than 2.5 amps per side and even at this current would be stressed. They were designed only to be used for charging. I recommend using an adapter or cutting off the male plug and soldering on a Deans directly to the output of the switch.
