Scratch Built Ignition???
Dr. Crash : It looks like you're not running a shielded plug wire & boot. Is this true & if so have you had any trouble with interference ? How did you figure out how much dwell time you needed on your pickup ? By the way that looks like a first class job on the conversion , what size prop does it spin ? Sorry for all the questions , thanks a ton for the pictures. That really helps alot. Thanks, Rob
