RCU Forums - View Single Post - Scratch Built Ignition???
Old 09-02-2003 | 02:42 AM
  #73
tkg
Default Re: ignition...home Built
Originally posted by captinjohn
So at this point, if a person used Jerry Harwells cicruit board and a CH coil....would that be a good combination???? Thanks Captinjohn
NOT a good idea.
The CH coil is for CDI not Kettering. If you use it with points/TIM-6 it will draw way to much current.
A CDI coil has a different winding ratio between primary and secondary.
Think of it as a transformer instead of a saturation coil.
