RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 04-30-2008 | 05:26 PM
  #567
wlcornelius
Default RE: Black Magic VF3 Build Thread
Hay Mike,
Well I took your advice an used a white primer by Lusterkote. I resanded the color an applyed two coats o0f white an wet sanded each along with 3 coats of Missle Red with wet sanding between coats an still came out Orange. I thought maybe the momokote Missle Red was shinner then the spray so I put on 2 coats of clear. I am given up. will send picks of final plane when done but here is the Cowl an belly pan. An the same problem with the canopy. I have learned the hard way that Monokote an lusterkote do'es not match.
ID:	940479   Click image for larger version
