I noticed when I installed the velocity stack on my 72 along with the Dubro filter that the engine mount was a good bit in the way. I was able to push the filter aside to install the engine on the mount.
Everyone have that problem?
I will have to do the same or grind away some of the motor mount, but grinding is probably not a good idea.
The filter will still function pushed aside, I might secure it with a tie wrap.
If you experience problems, use a bit more tubing for the feed line and let it loop below the tank and back up to the fuel nipple. It might be possible reversing this would help.
Thanks, Stallwart. Great Idea.
