Soldering Wire
Try cleaning the parts to be soldered with some 240 or 320 gritt
sand paper first, then use the flux.
Some wires , and cables are coated with an oil.
If you can coat the wire, or cable with solder first
(It's called tinning)
then solder them together.
Good Luck
Ralph V
