RE: Sig Hog Bipe Build
Hi all I to am converted to this Hog bipe I,ve build the top wing when it came of the board it got that twist in it so weigted it down and out with the ammonia trick and when it was right I replaced the trailing edge with a 1/4X 3/4 hard wood spar that certainly held it firm .I,ve also used a hard wood spar in the top spar in lieu of the balsa hopeing this will increase the over all strength of the wing , Question what do you think of the idea of using servos in the top wing also this is just a thought ?I figure it would then be less of a hassle hooking things up at airfeild ,all I have to do is plug it all in ,I,ll be running a 90 f.s
