RCU Forums - View Single Post - How to: "welding"
Old 05-05-2003 | 01:05 PM
Edwin
Default How to: "welding"
Same here. Just soldered some struts on a Phaeton 90. I found I was using too much heat. Went down to about 75watt soldering iron and everything was ok. Was soldering 5/32" steel rod. Do all the cleaning as described previously. If you use too much heat the flux evaporates and cannot do its job.
Edwin
