Leading Edge Gap Sealing
I just glued the leading edge sheeting on the left wing of my SIG Something extra. Every thing went fine except I have a small (1/32") gap between the leading edge spar and the sheeting on the last section between the ribs. What is the best way to seal the small gap and still add strength to the part where the sheeting and spar meet. Slight pressure will push the sheeting back and leave the sheeting drooping beetween the ribs. I want to make sure it is straight before sanding and applying the monokote. Any suggestions?
