Leading Edge Gap Sealing
Hooker:
Cut a narrow strip of balsa, edge glue it to the existing sheeting and the leading edge.
If the gap is where you sanded through the sheeting then lap the new sheeting over the existing sheeting by about 3/4" and restrain yourself when you sand it the next time.
In either case before covering put both wing halves on the joiner tube and check lateral balance.
Bill.
