RCU Forums - View Single Post - Fueling problems
Old 05-01-2008 | 01:06 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Fueling problems
The best solution for me is to simply do not not use a three line system. Cowling or not I always use a two line system just as on any trainer and always fuel toward the tank in the clunk carb line therefore flooding cannot occur.
Its very simple to loop the clunk to carb line out a slot or two holes in the cowl cutting the line there and inserting a 3/8 inch length of brass or alum tube. Very easy and fewer things to go wrong. I also use it for uncowled engine with rear neecle valves to simplyfy replacing that line behind the engine.
In the topside photo of the red/black Cap you can see the fill line that is just pulled up a little and fueled from there.
This method also provide the added benefit of makine pinch tuning possible, A method much preferred by me.
John
ID:	940894   Click image for larger version
ID:	940895   Click image for larger version
ID:	940896   Click image for larger version
ID:	940897   Click image for larger version
ID:	940898   Click image for larger version
ID:	940899   Click image for larger version
