RE: How is Wing tip Laminating Done?
When laminating place pins in place at strategic points around the shape on the plan, then after soaking a 1/16' X 1/4wrap it around the curve then take next strip and after applying glue [ alphatic reson] soak and pin and wrap around previous strip,pining as required and so on til proper width is aquired,of coarse removing pins as you aproach them and replaceing them after passing. Let dry thorughly before unpinning.
