RCU Forums - View Single Post - Flying using a VPP system - switch or lever
Old 05-01-2008 | 06:21 PM
darticus
Default Flying using a VPP system - switch or lever
Does the plane fly normal in every respect until you use the pitch change. Is the pitch change controlled by a switch or the left throttle lever? On my Realflight it seems as the Vpp is controlled by a toggle switch. You put throttle lever down and flip the top toggle switch for full reverse. Is this the way it should be?
