RCU Forums - View Single Post - Engine Break-in like the pros
Old 05-01-2008 | 06:40 PM
JB COMP's Avatar
JB COMP
Default RE: Engine Break-in like the pros
I'm done using the heat cycle method and run 5min instead of the 2-3min
You need the engine temp at least 210 to start breaking it in. You can run your engine almost as hot as you want as long as you're not lean.
