I just build a canister muffler for a 72cc engine.
I used 2-5/8 id tubes and the engine was choking out.
I installed the third pipe and now it runs pretty good.
2 hole muffler:
http://www.rcuvideos.com/item/BMV2KV388GZSF0NZ
3 hole muffler:
http://www.rcuvideos.com/item/GYZZ4BDXYD2G4VVP
If you only use 2 exhaust tubes they will have to be bigger than 5/8
Any way that is what I found.
By the way I just finnished a 61cc Echo Twin conversion
It does use 5/8 tubes and it does run good.
http://www.rcuvideos.com/item/8PXSLQ2FFLSVFK62
