RCU Forums - View Single Post - throttle set up
Old 05-02-2008 | 04:03 AM
MJ-MERLIN's Avatar
MJ-MERLIN
Default throttle set up
Hi
Just a quick question on throttle set up.
I have been setting up the throttle on my OS120FS
I have set the EPA on the low end by having the engine running and closing the throttle till I come to a point where the idle is nice and low but still reliable.
The upper travel was set by looking in to the carb and setting is so the carb is fully open.
When the engine is running and at full throttle I can move the throttle stick about 3-4 clicks and it doesn’t seem to make a difference in the rpm,
This was obviously done on the ground without the model moving.
My question is......
To get the best resolution in throttle control do I set the upper limit to the carb or do I do it to the generated rpm ???
