ORIGINAL: schlags62
Why does my clutch bell keep sliding up off of the clutches, the bolt that hold it on is tight and as soon as I put it all back together and run it a couple of minutes it slids up and makes the mesh only about half the gear.[:@]
If there is no washer at the end of the clitch bell you can get one at the hardware store for a couple cents, BUT make sure there is a small portion of the inside shaft sticking out, just a tiny bit, so that when you put the washer on and lock down the bolt, using lock tight, it doesn't seat against the end of the clutch bell. Other wise you will lock down the clutch bell too.
