RCU Forums - View Single Post - ST-40 needs new battery pack
Old 05-02-2008 | 01:11 PM
Jburry's Avatar
Jburry
Default RE: ST-40 needs new battery pack
Using 2 cells instead of 3 will reduce your power by 33%. Probably you don't want that
Using NIMH or NICAD cells will increase the weight of the plane, and that'll have a negative impact on flight characteristics.
Best to replace with the same size pack, or one with a slightly better mah rating, in the same number of cells.
Good luck,
J
