RCU Forums - View Single Post - throttle set up
Old 05-02-2008 | 02:05 PM
Rush7's Avatar
Rush7
My Feedback: (74)
Default RE: throttle set up
Back your EPA down until you see a change in RPM's then go back up slowly until the RPM's max out. Just remember the higher you can get your end points the better your throttle reponse will be.
I try to get at least 100 on both sides of the EPA.
I have also found that most engines RPM's max out before the barrel or the butterfly in the carb becomes 100% open. It is very close to 100% but not always at 100%.
